StarWind Virtual SAN® Asynchronous replication and Disaster Recovery
  • January 31, 2018
  • 13 min read
IMPORTANT NOTE: Starting from 14869 build, the Asynchronous replication feature was excluded and deprecated. Please remove all Asynchronous replicas and LSFS devices before the update. See more information in the release notes: https://www.starwindsoftware.com/release-notes-build
Introduction to Asynchronous Replication
Having a disaster recovery site is crucial for companies that care about their data safety, and it’s a MUST for ones which are under the regulatory requirements. On-site Redundancy (RAID, Synchronous Mirroring, etc.) does not guarantee data protection from hurricanes, floods, and earthquakes that can completely destroy the primary datacenter. To reach the maximum data security, StarWind provides asynchronous replication functionality.
The combination of StarWind data-compression and replication technologies enable to eliminate the typical for conventional DR implementations issues: high cost, performance drops, and risk of data discontinuity. Allowing the installation to take place in the cloud VM for DR purposes and moving the replication and data compression to the background, it prevents the common pitfalls found in traditional DR solutions.
This document is intended for StarWind users who want to learn to set up asynchronous replication, and the basics of snapshot management. It describes the process in detail, being a comprehensive step-by-step instruction that is good for beginners and seasoned professionals.
StarWind VSAN System Requirements
Pre-Configuring the Servers
The reference network diagram of the configuration described further in this guide is provided below.
NOTE: Since Asynchronous node uses LSFS device by design, please, make sure that you are aware of LSFS device features and the node hardware fits LSFS device requirements, described here: https://www.starwindsoftware.com/resource-library/lsfs-container-technical-description
Installing StarWind VSAN for Hyper-V
1. Download the StarWind setup executable file from the StarWind website:
https://www.starwind.com/registration-starwind-virtual-san
2. Launch the downloaded setup file on the server to install StarWind Virtual SAN or one of its components. The Setup wizard will appear. Read and accept the License Agreement.
StarWind License agreement
3. Carefully read the information about the new features and improvements. Red text indicates warnings for users that are updating the existing software installations.
4. Select Browse to modify the installation path if necessary. Click on Next to continue.
select destination location
5. Select the following components for the minimum setup:
  • StarWind Virtual SAN Service. The StarWind Virtual SAN service is the “core” of the software. It can create iSCSI targets as well as share virtual and physical devices. The service can be managed from StarWind Management Console on any Windows computer that is on the same network. Alternatively, the service can be managed from StarWind Web Console deployed separately.
  • StarWind Management Console. Management Console is the Graphic User Interface (GUI) part of the software that controls and monitors all storage-related operations (e.g., allows users to create targets and devices on StarWind Virtual SAN servers connected to the network).
    NOTE: To manage StarWind Virtual SAN installed on a Windows Server Core edition with no GUI, StarWind Management Console should be installed on a different computer running the GUI-enabled Windows edition.
6. Specify Start Menu Folder.
Select start menu folder
7.
 Enable the checkbox if a desktop icon needs to be created. Click on Next to continue.
8. When the license key prompt appears, choose the appropriate option:
  • request time-limited fully functional evaluation key.
  • request FREE version key.
  • relect the previously purchased commercial license key.
9. Click on the Browse button to locate the license file.
10. Review the licensing information.
11. Verify the installation settings. Click on Back to make any changes or Install to proceed with installation.
12. Enable the appropriate checkbox to launch StarWind Management Console right after the setup wizard is closed and click on Finish.
13. Repeat the installation steps on the partner node.
Creating Asynchronous Replication
NOTE: Asynchronous replica can be added to a standalone or an HA device. In this document, the asynchronous replica is created for a standalone device. Before replica creation, please, create necessary devices according to these guides:
Creating a standalone device: https://www.starwindsoftware.com/help/CreatingaNewImageFileDevice.html
Creating HA device: https://www.starwindsoftware.com/help/ConfiguringSynchronousReplication.html
1. Open StarWind Management Console, select device and right click on it to select the Replication Manager.
Asybc Replication Manager
2. The Replication Manager window will appear. Press the Add Replica button.
wp-image-12409
3. Select Asynchronous “One-Way” Replication and click Next to proceed.
wp-image-12410
4. Enter the IP address of the Asynchronous node.
Async Host name
5. Choose the Create New Partner Device option and click Next.
wp-image-12412
6. Specify the partner device location if necessary. You also can modify the device target name.
Replication Wizard
7. Click Change Network Settings.
8. Specify the proper network for asynchronous replication between two nodes, click OK and then Next.
Syncronization Channels
9. Select Synchronize from existing Device as a partner device initialization mode and click Next.
wp-image-12416
10. Specify Scheduler settings and click Next.
NOTE: The size of journal files and number of snapshots depends on the settings, specified in this window.
wp-image-12417
11. Specify the path for journal files and click Next.
NOTE: The journal files will be located on the node which has the original device. However, it is highly recommended do not store journal files on the same drive where the original device is located.
Also, do not use C:\ drive as the path for journal files to avoid any issues with Windows OS.
wp-image-12418
12. If you choose the same drive where the StarWind device is located, you will receive the warning about possible performance issues. If you do not have the additional volume to store the journals, you can click I understand the potential problem. Use selected path.
wp-image-12419
13. Press the Create Replica button.
wp-image-12420
14. Wait until StarWind service creates a device and click Close to complete the device creation.
Replication manager
Restoring from an Asynchronous Replica
There are two possible ways for Hyper-V environment to bring the production online from an asynchronously-replicated node if the primary nodes are unavailable because of a disaster. The way to restore depends on particular needs:
Restoring Virtual Machines from a Read-Only Snapshot:
1. In StarWind Management console open device on the Asynchronous node, and click Snapshot Manager.
2. Select the Snapshot from the list and click Mount Snapshot. Snapshot will be mounted as a separate device in the Read-Only mode.
Snapshots
3. In the emerged window, specify target parameters. Target alias, as well as the target name, can be modified if needed.
Mount Snapshot
Click OK to mount the snapshot.
4. Device mounted from the snapshot should look like one in StarWind Management Console (look the figure below).
NOTE: Device mounted from a snapshot is in the Read-Only mode by design.
5. To access data on the read-only device, the target should be connected in Microsoft iSCSI Initiator.
Launch Microsoft iSCSI Initiator in Server Management tools or by deploying iscsicpl in the command line interface.
6. Navigate to the Discovery tab in the iSCSI Initiator Properties window.
7. Click the Discover Portal button. Once Discover Target Portal dialog appears, type in 127.0.0.1 to discover targets from the local host and click the Advanced button.
iSCSI initiator properties
8. Select Microsoft iSCSI Initiator as the Local adapter and click OK twice.
Advanced Setting
9. Navigate to the Targets tab, select the Snapshot target and click Connect.
NOTE: If targets are not listed, check the firewall settings of the StarWind Server and the list of networks served by the StarWind Server (go to StarWind Management Console -> Configuration -> Network).
10. Add the target to the Favorites list and enable multi-path. Click Advanced.
Connect to target
11. Select 127.0.0.1 from the Target portal IP drop-down list and set Microsoft iSCSI Initiator as the default initiator.
Advanced Setting
Click OK twice and complete the connection process.
12. Make sure that target is connected as in the picture below:
13. Open the Disk Management tab and bring the new disk online.
wp-image-12432
14. Once the Volume with the Virtual Machines or files is available, open Hyper-V Manager and click Import Virtual Machine…
Import Vitrual Machine
15. Specify the path to the Virtual Machine located on the Read-Only disk (mounted from snapshot) and click Next.
wp-image-12434
16. Select Virtual Machine and click Next.
wp-image-12435
17. Choose the Restore the Virtual Machine option.
wp-image-12436
18. In Choose Destination check Store the Virtual Machine in a different location, specify the local path on the DR node and click Next.
wp-image-12437
19. Choose a folder to store the Virtual Hard Disk and click Next.
wp-image-12438
20. Check the Import details and click Finish to complete and close the wizard. Once Virtual Machine import is done you can start the Virtual Machine in Hyper-V Manager.
Restoring Virtual Machines from the replicated device on the Asynchronous node
By design, the replicated device on the Asynchronous node is not allowed for any clients’ connections while the replica is not fixed at the specific time point. To make the target available for the client connections, it has to be re-added in StarWind Management console.
1. Open StarWind Management console, choose a device with Asynchronous replication mode, click Replication Manager and click Remove Replica in the appeared window.
2. Confirm the replica removal by clicking Yes button.
3. Open StarWind Management console and click Add Device (advanced) to add the device in Asynchronous replication mode one more time
4. Add Device Wizard will appear. Select Hard Disk Device and click Next.
wp-image-12441
5. Select a Virtual disk and click Next.
wp-image-12442
6. In the Virtual Disk Location window, choose Use an Existing Virtual Disk and specify the path to the device in Asynchronous replication mode. The path to file with the spsp extension should be specified and the Read-Only Mode checkbox should be unchecked.
Add Device Wizard
7. Press Create New to create the header file for the device which will be added.
wp-image-12444
8. Specify the same Block Size and click Next.
wp-image-12445
9. Modify LSFS settings, if required, and click Next.
10. Define the caching policy, specify the cache size, and click Next.
wp-image-12446
NOTE: It is not recommended to configure the cache in Write-Back mode on Standalone devices in order to avoid possible data corruption upon power outage or incorrect service shutdown.
11. Define the Flash Cache Parameters policy and size if necessary. Choose SSD location in the wizard.
NOTE: The recommended size of the L2 cache is 10% of the initial StarWind device size.
Add Device Manager
12. Modify the Target Alias and target name, if needed, and click Next.
Add Device Manager
13. Click Create and Close to add a new device.
wp-image-12449
14. The re-added device should look like as one in the figure below.
StarWind Console Manager
15. Discover targets and connect the newly-created target to ISCSI initiator as it is described in steps 19-25. The connected target should look like one in the screenshot below:
wp-image-12451
16. Open Disk Management and bring the new disk online.
wp-image-12452
17. Once the Volume with Virtual Machines or files is available, open the Hyper-V Manager and click Import Virtual Machine…
wp-image-12453
18. Specify the path to the Virtual Machine which is located on the recently connected disk (mounted from snapshot) and click Next.
wp-image-12454
19. Select Virtual Machine, click Next, and choose the Register the Virtual Machine in-place option. Complete the wizard to register the Virtual Machine.
wp-image-12455
